Exporting an image file
Command
Path
Export Image File
File > Export
The Export Image File command exports a rendered drawing to a variety of file formats, including GIF, JPG, TIF, BMP, WMPhoto, and others. Different portions of the image can be selected for export.
The list of image formats is populated depending upon the operating system and installed drivers.
The following table lists the standard image export formats that are supported.
Export formats
Mac
Windows
BMP
X
X
Portable Bitmap (PBM)
X
GIF
X
X
JPEG
X
X
JPEG2000
X
PNG
X
X
Photoshop (.psd)
X
TGA
X
TIFF
X
X
OpenEXR
X
WMPhoto
X
DDS
X
HEIF
X
X
ASTC textures
X
KTX textures
X
PVRTC textures
X
To export an image file:
Select the command.
The Export Image File dialog box opens.
Select the export options, and then click Render or Wireframe to display the exported image preview.
Parameter
Description
Export Area
All Visible Objects
Exports an image that includes all visible objects (objects do not have to be currently on screen to be considered visible)
Current View
Exports an image that is exactly as it displays on the current screen
All Pages as Single Image
Saves all pages in the print area as one image. By default, the image dimensions are set to match the print area specifications in the Page Setup dialog box. The image dimensions can be changed, but must remain proportional to the print area aspect ratio.
Each Page as Separate Image
Saves each page in the print area as separate images. By default, the image dimensions are set to match the page size specifications in the Page Setup dialog box. The image dimensions can be changed, but must remain proportional to the page size aspect ratio.
Marquee
Exports an image within a user-created marquee. Select this option and then click Draw Marquee to temporarily close the dialog box. Click and drag to specify the area for export; the marquee dimensions are displayed on the Data bar. Click to set the export area and return to the Export Image File dialog box. The Pixel Dimensions of the image are automatically set to the marquee dimensions.
Dimensions
Lock Aspect Ratio
Maintains the image aspect ratio when specifying dimensions
Resolution
Specifies the printed image resolution in pixels over inches
Pixel Dimensions
Width/Height
Specifies the exported image dimensions; if Lock Aspect Ratio is selected, changes to one dimension will update the other to maintain the aspect ratio
Print Size
Width/Height
Specifies the printed image dimensions in the selected Unit; if Lock Aspect Ratio is selected, changes to one dimension will update the other to maintain the aspect ratio
Units
Select a unit to apply to the Print Size parameters
Preview
Displays a rendered or wireframe preview according to the current settings
Render
Updates the preview with a rendered view using the currently set rendering option
Wireframe
Updates the preview with a wireframe view
Memory Required/Estimated File Size
Estimates the amount of memory required for the export and the approximate file size of the exported file, based on the current settings
Update
Updates the estimated memory and file size requirements
Format
File Type
Select the file format for the exported image
Color
Specify whether to export the image in Full color, Grayscale, or Black and white
Save Alpha Channel
For file types that allow transparency and when full color is specified, select this option to export the image with a transparent background.
Preview the result by clicking the Render or Wireframe button; the opaque white background is replaced with the checkerboard pattern that indicates transparency.
Quality
For file formats that observe a quality setting, drag the Opacity slider to the left to decrease the image quality or to the right to increase quality
Update visible out of date viewports prior to exporting
Automatically updates any visible, out-of-date viewports before exporting
Reset all plug-in objects that require a reset prior to exporting
Automatically resets plug-in objects that require an update (such as data stamps) before exporting
Export Georeferencing File
(Design Suite required)
Available only if the current design layer is georeferenced. Along with the image file, exports a worldfile that describes the exported image’s location, scale, and rotation in the geographic coordinate system. If multiple georeferenced layers are visible, the worldfile will be based on the active layer. See GIS and georeferencing for more information.
Click Save.
In the dialog box that opens, provide a name for the file; the program adds the file extension according to the file format selected. If the Each Page as a Separate Image is selected for export, the program automatically appends an incremental number to each file name.
Click Save.
A new file is created without changing the original drawing file. This new file can then be opened in other applications or imported into another software program.
